Examples
config.extraPlugins = 'youtube';
config.extraPlugins = 'sourcedialog';:
The appropriate buttons are also called in the Custom Toolbar setup.
When I try to put either one of these in config.js the work fine but when I put both in at the same time only one will work and which one will vary.
Any ideas?
Bill
You should define both
You should define both additional plugins in one declaration, as described in the API docs:
Thank you
Thank you. Now I can move ahead - when I find the best Youtube pljugin..
Bill
