Hello, i'have installed FCKeditor 2.4.3 on Plone 2.5.3, the installation HAS HAD POSITIVE , BUT WHEN I TRY TO ACTIVATE the EDITOR, the FOLLOWING ERROR APPEARS in Plone
Site error
This site encountered an error trying to fulfill your request. The errors were:
Error Type
TypeError
Error Value
getFck_basehref() takes exactly 1 argument (0 given)
Some suggestion ?, thanks
Site error
Error Type
TypeError
Error Value
Re: problems with installation
I get this error message
Can you help with this? Thank you.
I have tested this on Windows XP Pro and Windows 2003. I have tried both FCKeditor 2.4.5 and 2.4.6. I am running Zope 2.9.7 and Plone 2.5.3. When I try to open any page for editing, I get this error message in either version.
fckeditor not installed correctly: getFck_basehref() takes exactly 1 argument (0 given)
The editor does not open at all.
I have had version 2.4.2 working
Note: It appears to work in FCKEditor 2.4.5 after I replaced the file getFck_basehref.py with the one in version 2.4.2. Can you tell me if this might be the correct fix? Other possibilities we are thinking of are, has it been tested with Zope 2.9.7 and Plone 2.5.3? Is it possible it is the Zope or Python version that is the problem?
Steps to reproduce:
Uninstall current version of FCKeditor
Copy FCKeditor folder into Plone instance Products folder
Restart Zope
Use portal_quick installer to install in Plone site.
Login with manager rights
Open any document
Click on Edit tab
