" put cursor in 1st cell, then hold down the shift key and right click in the 2nd cell and choose merge cells. that works in ie 6 for me.
I'm using IE 6 and I found you must have info in each cell before they merge. You have to highlite the cells to merge and right-click in the LEFT cell of the ones you're merging. "
RE: merge Cell problem and .. In IE6.0
but it works not too.
I can't make or keep highlite on cells...
T_T
