<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>FCKeditor - Sample</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="robots" content="noindex, nofollow" />
<link href="../sample.css" rel="stylesheet" type="text/css" />
<script type="text/javascript" src="../../fckeditor.js"></script>
</head>
<body>
<h1>
FCKeditor - JavaScript - Sample 1
</h1>
<div>
This sample displays a normal HTML form with an FCKeditor with full features enabled.
</div>
<hr />
<form action="../php/sampleposteddata.php" method="post" target="_blank">
// Automatically calculates the editor base path based on the _samples directory.
// This is usefull only for these samples. A real application should use something like this:
// oFCKeditor.BasePath = '/fckeditor/' ; // '/fckeditor/' is the default value.
var sBasePath = document.location.href.substring(0,document.location.href.lastIndexOf('_samples')) ;
var oFCKeditor = new FCKeditor( 'FCKeditor1' ) ;
oFCKeditor.BasePath = sBasePath ;
oFCKeditor.Height = 300 ;
oFCKeditor.Value = '<p>This is some <strong>sample text<\/strong>. You are using <a href="http://www.fckeditor.net/">FCKeditor<\/a>.<\/p>' ;
oFCKeditor.Create() ;
<br />
<input type="submit" value="Submit" />
</form>
</body>
</html>var sBasePath = document.location.href.substring(0,document.location.href.lastIndexOf('_samples')) ;var sBasePath = document.location.href.substring(0,document.location.href.lastIndexOf('samples')) ;
