The "Browse Server" button is missing from my installation so I cannot insert any images or links, only via absolute URLs. I can't live like that.
I have set up a new site with Drupal installed the lastes wysiwyg, imce, imce_wysiwyg and downloaded the ckeditor from http://ckeditor.com/ I have installed it properly in sites/all/libraries/ckeditor so that the path is sites/all/libraries/ckeditor/ckeditor.js . This is true! I swear!
I have also tried it in sites/all/modules/ckeditor ... nada ...
I have checked in wysiwyg that imce is checked, it is. I have the buttons for images and links in the "full html" profile for the admin.
I have googled and looked on every help site I could find; I also installed tinymce in the libraries folder because somewhere it said that helped. I have two other sites set up with ckeditor which work fine - this one does not.
What is wrong? I need to finish the site but can't because it's a drag to ftp all images and do absolute URLs.
thanks,
Sorry to hear you are having
Sorry to hear you are having issues. Do note, however, that we do not support the wysiwyg module -- this is a third-party application that we have no control over.
Have you tried using the official CKEditor for Drupal module? The documentation is located here: http://docs.cksource.com/CKEditor_for_Drupal/Open_Source
