i have even hard time to describe the problem. i have an admin area with CRUD made for a client. i have no problem with the development version of the site, the crud work perfect.
but the live version sometimes work and other times does not work, and give different errors for the same situation:
i have a lecture section . i try to insert a lecture, and it works. the next one i try i get "you have an error with the SQL near....". so i try again and i get: " no database selected".
then i try another and it works.
the same when i try to update: sometimes it work and other time i get those errors.
when i enter an english text it works but all the problems comes when i use Hebrew, and i must use Hebrew since it is an Hebrew site.
maybe that is the problem? anyone had this too?
best regards
best regards
