Funny you should ask, I am looking for this infomration as well.
So far what I have found is that this fucntionality is called Context Menus.
What I did was a search for the right click for the Image Properties piece and found it in a glbal file and the following two files:
- fckeditor_ie_2.js - fckcontextmenu.js
I am trying to change the Image Properties piece to open a plugin that I added called iManager. So far, I am lost but I will start looking online in tutorials to find out how to create a context menu. All I want the image properties piece to do is open up iManager instead of the default FCK image dialog box.
RE: Right Click on FCKeditor, how it works ?
- fckeditor_ie_2.js
- fckcontextmenu.js
