I may be missing something simple here, but anyway, here goes. I have a simple form, a couple of inputs, and the FCK object, which should contain the main body of text for the form. If I use an onClick to call a Prototype Ajax.Updater function to do something with the data, PHP Info shows that nothing from the FCK object is passed. This does work if I use the Submit, but I'd really like to use the Prototype function still.
Does the FCK editor not work well with the Ajax.Updater call?
Thanks for any advice!
Re: Prototype Ajax.Updater Problem
http://docs.fckeditor.net/FCKeditor_2.x ... AjaxSubmit
