Thanks for a great product. Been using it on and off for years.
I'm having a problem with images using CKEditor 4.1. My requirements are to disable the standard image button, while still allowing images to be included in the editor content. Images are added via a custom file manager / file upload but this is not contributing to the problem. When loading the editor up with content containing an img tag, the image is shown at first, and then removed.
- The image button is disabled like so: config.removeButtons = 'Image';
I played with ACF a little to try to get it to allow images.
- extraAllowedContent: 'img' when instantiating the editor, and
- config.extraAllowedContent: 'img' in the custom config file
This did not work. Strangely, running the 'filter check':
editor = CKEDITOR.instances['%instance_id%'];
editor.filter.check('img');
returns true.
I'm using an inline editor.
Have now disabled ACF: config.allowedContent = true, and this has prevented images from being stripped.
However, now when I try to align an image to the right, the text follows it. The support for a floated image is gone.
Question: How can I achieve all the requirements:
1. Remove the standard image button
2. Prevent the image properties dialog on double-click
3. Not have images stripped out (would prefer to leave ACF on if possible)
4. Still be able to align images to the right?
Thanks in advance
Images being stripped
I'm having the same issue with images being stripped. I'd prefer not to have the image toolbar shown also, but images are being stripped without it. Tried the suggestion above to extraAllowedContent which also did not work for me.
