Hi everyone,
I am fairly new to web programming so please be patient with my question.
I copied the aspx folder from my Fckeditor.net project into my fckeditor/_samples folder in my webproject.
I tried to compile and i get the errors of
Error 1 Could not load type 'FredCK.FCKeditorV2.Samples.Sample02'. <mywebproject>fckeditor\_samples\aspx\sample02.aspx
and
Error 2 Could not load type 'FredCK.FCKeditorV2.Samples.sample031'. <mywebproject>\fckeditor\_samples\aspx\sample03.ascx 2
I have noticed that sample02.aspx page is using the attribute Codebehind which VWD considers no longer supported.Is this true.
Thank you
and
Thank you
Re: Problems running the asp.net samples
Thanx,
Klaus
