Problem using the File Browser outside of FCKeditor
function SetUrl(url)
var labels=document.getElementsByID('myTxt');
labels.value=url;
function OpenImageBrowser()
window.open('FCKeditor/editor/filemanager/browser/default/browser.html?Type=Image&Connector=connectors/asp/connector.asp','BrowseWindow','toolbar=no,status=no,resizable=yes,dependent=yes,scrollbars=yes,width=600,height=400')
<input type="text" ID="myTxt" value="">
<input type="button" value="Pick Image" onclick="OpenImageBrowser();" />
Re: Problem using the File Browser outside of FCKeditor
<script type="text/javascript"> var target; function SetUrl(url) { document.getElementById(target).value = url; } function OpenImageBrowser(t) { target = t; window.open('/FCKeditor/editor/filemanager/browser/default/browser.html?Type=Image&Connector=/FCKeditor/editor/filemanager/connectors/asp/connector.asp','BrowseWindow','toolbar=no,status=no,resizable=yes,dependent=yes,scrollbars=yes,width=600,height=400') } </script>just add "/FCKeditor/editor/filemanager/" before connectors/asp/connector.asp
before:
after:
then file browser will get the correct path and work fine.
just add the follow codes to your file which you want to use the File Browser outside of FCKeditor is ok
<script type="text/javascript"> var target; function SetUrl(url) { document.getElementById(target).value = url; } function OpenImageBrowser(t) { target = t; window.open('/FCKeditor/editor/filemanager/browser/default/browser.html?Type=Image&Connector=/FCKeditor/editor/filemanager/connectors/asp/connector.asp','BrowseWindow','toolbar=no,status=no,resizable=yes,dependent=yes,scrollbars=yes,width=600,height=400') } </script> <input type="text" ID="myTxt" value=""> <input type="button" value="Pick Image" onclick="OpenImageBrowser('myTxt');" />
