http://www.livskallan.nu/test/meditation_admin.php
<?php function input() { $DocumentInfo=addslashes($this->DocumentInfo); $connect = mysql_connect ("localhost", "livskallan", "gfdsa") or die (mysql_error()); $databas = mysql_select_db("livskallan"); $sql = "UPDATE meditation SET DocumentInfo = '$DocumentInfo'"; mysql_query("$sql"); mysql_close($connect); } function show_result() { $connect = mysql_connect ("localhost", "livskallan", "gfdsa") or die (mysql_error()); $databas = mysql_select_db("livskallan"); $sql = "SELECT * FROM meditation"; $result = mysql_query("$sql"); $rad=mysql_fetch_row($result); include("../FCKeditor/fckeditor.php") ; ?>
<html>
<head>
<title>Meditation - Admin</title>
<meta name="robots" content="noindex, nofollow">
<link href="../FCKeditor/sample.css" rel="stylesheet" type="text/css" />
</head>
<body>
<h1>Meditation - Admin</h1>
Hr kan du ndra p meditaionstexten.
<hr>
<form method="post" action="<?=$PHP_SELF?>">
<?php
$oFCKeditor = new FCKeditor('FCKeditor1') ;
$oFCKeditor->BasePath = '/FCKeditor/' ;
$oFCKeditor->Value = "$rad[0]";
$oFCKeditor->Create() ;
<br>
<input type="submit" value="Skicka">
</form>
if(!empty($_POST['DocumentInfo']))input();
show_result();
</body>
</html>
RE: Problem using FCKeditor with MySQL
should be:
$oFCKeditor->Value = $rad[0];
if you need to keep the magic quotoes then you need:
$oFCKeditor->Value = "{$rad[0]}";
