My CSS displays correctly when the FullPage option is off, but does not work when FullPage is on:
Page does Not Display Correctly:
$oFCKeditor->Config['EditorAreaCSS'] = '../../css/layout.css'; // Set this to the path for your css file
$oFCKeditor->Config['FullPage'] = true ;
Page Does Display Correctly:
//$oFCKeditor->Config['FullPage'] = true ;
Can anyone provide some help with his?
Re: Problem using CSS with FullPage=true
It would be strange otherwise to use some styles while editing and when you save the file don't have that same styles available for the visitors.
I am trying to add some css to an email message created with FCKeditor. I have set FullPage=true and in the source I can see the html, head and body tags. How do I add a stylesheet link into the head part by default. I don't want the end user to have to click on the Source button and do it manually.
I tried setting the default value to include the html, head, link, body tags but FCK removes these and replaces with its own tags. Is there any way to specify a stylesheet in the head of a FullPage=true page?
Cheers,
Dave
