I am using FCKEditor v2 with my web application. My application is configured with Forms authentication and I am using default theming which is defined into web.config.
My problem is that, when I use the FCKEditor without the Forms Authentication and without Default theming, it works fine and I am able to browse server folder "/userfiles/" and able to see the images as well. But when I need to use FCKEditor with the Forms Authentication and Default theming it creates problem when I try to browse the server or try to upload files to the server.
I have set all the basic settings into the Editor and created "/userfiles/" into the root of the application.
Here I have attached the error screen which I am getting.
Please help to sort out my problem.
Best regards,
Haidar
Best regards,
Haidar
