I've been trying for awhile to get FCKeditor_2.4.3 installed and am repeatedly running into the same problem. I've never installed a 3rd party control into .net (Visual Studio 2005) so maybe I'm doing something totally wrong.
I downloaded the .zip file and zipped it to the root of my web site as detailed in the installation instructions. I then go to VS and refresh my Solution Explorer and the directory shows up. But, when I go to build my web site I consistently get the the same build 2 errors:
-Could not load type 'FredCK.FCKeditorV2.FileBrowserConnector'. File: connector.aspx Line: 1
-Validation(): Element 'html' occurs too few times. File: connector.aspx Line:30
I'm unzipping the download straight into my website and immediately building it, so I'm lost as to what could possibly be wrong. Any advice would be appreciated.
Re: Installation Problems
