We started using FCKEditor in our application and it works great except for a problem with the images. Our site is configured like this:
wconnect\ (this is root folder)
wconnect\graphics\
wconnect\FCKEditor\
So in our pages to display images we are using src="graphics/someimage.gif" but that does not display correctly when opened in FCK because it runs in another folder, it needs to be src="../../graphics/someimage.gif"
I tried different configurations by moving the 'Editor' folder and using the Basepath property, but I could not get it to work.
The only solution I can think of would be to move the content of FCKEditor\Editor to our site root, which I really don't like.
Any other solution/idea ? Thanks
Sylvain
wconnect\graphics\
wconnect\FCKEditor\
Sylvain
RE: Images path problems
In any case, if you want to use FCKeditor to manage your images, you will have to place your images in a folder called Images (userFiles/Images; userFiles/Files; ...), because FCKeditor uploads all images to the 'Images' folder of your userFiles directory.
"Your images should point to src='/wconnect/graphics/someimage.gif' "
This is using a fullpath which is not correct, that would imply a modification to all pages of our site, I don't want to use the wconnect/ folder in the paths, the default web site in the web server points to this folder. I want to use relative paths to display my images, not starting from the root.
So unless I'm mistaken, if I don't use /graphics/someimage.gif I won't be able to have the existing HTML to display correctly in the editor ?
thanks for your reply
