I do have 2 problems and I'm hopeless getting it to work (tried 5 days) so I decided to pay for someone to help me. This is the problem:
I've got an IFrame in my project. In this IFrame (and in the editor, too) should all <script tags be executed. Furthermore should I have the possibility to click on an link in the iframe so that this link will work on the first time I klicked. In the moment I have to click three times. It should work in FF 2 upwards and IE.
I hope you can help me.
Thank you!
Stephan
Thank you!
Stephan
Re: IFrame Problems and job offer
me again. If someone could help me, please contact. I think we will agree upon the price. Use PM please.
Thank you very much.
Stephan
document.write('hello');I'll tell you what happens:
The first time that you edit the page you see: "hello". Then you save the page and check it in your live site and then it suddendly appears: "hellohello".
Ups.
So you edit again and there they are the two hellos although you did save only one. so you delete one of them. go to your site and again the two hellos are there. If you don't delete but you save the page, then you get three hellos.
Imagine any other script that includes some ads, or any other fancy effect, you are saving the output of the script and the original script again.
You should go back to the drawing board and think again about what you want.
yes, I thought about this, too. But I only wolud use several commands like resizing an iframe in the editor area and the commands inside the iframe (which does not do any changes in the editor). It would be okay, too, if only the iframe would execute all script-tags in there (in FF2 and IE).
Do you think that is possible?
Thank You!
Stephan
Stephan
