I have manage to install FCK on a page called admin - and everything is working fine, incl. image browsing. Here the code:
<!--#include file="template2.asp"-->
<!-- #INCLUDE file="FCKeditor/fckeditor.asp" -->
<%function title()%>
Admin
<%end function%>
<%function content()%>
<div class="title" style="font-size:18">Admin area & Editor
<body>
<form action="webdesign.asp" method="post">
Dim oFCKeditor
Set oFCKeditor = New FCKeditor
oFCKeditor.BasePath = "/FCKeditor/"
oFCKeditor.Create "FCKeditor1"
<br>
<input type="submit" value="Submit">
</form>
</body>
<%end function%>
I have made a testpage called webdesign, where I want the output from the editor, but I am totally lost. I know, I shall make something with a form, but I don't know how?
Can anybody give me this code?
My testpage, where I want it to show up look like at the moment like this:
Product 2
<%end function%>
<div class="title" style="font-size:18">Web Design</div>
<% If Request.Form("webdesign") <> "" Then %>
Dim sValue
sValue = Request.Form( "FCKeditor1" )
<%End if%>
<%end function%>
Thanks for helping me!
Can anybody tell me, which code I shall put in
Admin
<%end function%>
<body>
Dim oFCKeditor
<br>
</form>
</body>
<%end function%>
Product 2
<%end function%>
Dim sValue
<%End if%>
<%end function%>
RE: I try to learn - but I need help...
RE: I try to learn - nobody knows about ASP?
Maybe my quistion is stupid. I don't know? I am new in this things, and I don't know how to solve the problem.
Please try to help me!
I have an ASP page, and no database.
I only want the content from the editor to show up on another asp page. Is this possible?
Look at my code in "I try to learn..."
which tests if the webdesign field was posted empty and as I see, the form doesn't have such a field.
I think you wanted to write <% If Request.Form("FCKeditor1") <> "" Then %>
However, I would write those instructions in oher way:
If Trim(sValue) <> "" Then
' .... store the text in database, for example
End If
And a question for you now. What's the goal of:
Admin
<%end function%>
Mind the context changes. don't make abuse of <% %>
Jaime
