I'm having some problems, i'm new to CKeditor and i currently have a php website that i'm moving servers for a client, normally the user will login to ckeditor via the admin folder login screen and this allows her to edit text and photos etc.
I have transferred all the web files over from one server to the other yet i cannot get the site to work properly, first problem is that the content of the website, eg. text and pictures are not showing up, i just get the main web template with a blank white area for the text, the links and menu bar are showing.
Also i cannot login via the admin screen, not sure why but i'm guessing this all has something to do with ckeditor.
Is there anything specific i need to do in order to successfully migrate this site?
Any ideas would be most apreciated, i'm stuck right now!
I'm managed to narrow down the problem with the text not showing, i notice in the php code it has div tags which point to files which contain the content for each part of the page, all these files are on the server yet no content is displaying. I'm guessing it has something to do with the ckeditor setting, anyone know what the problem might be?
Re: How to migrate a website that uses CKeditor?
I did try the contact us link but not had any reply and desperate to get an answer.
i don't seem to be having much luck in getting a reply on here..
Re: HELP!* How to migrate a website that uses CKeditor?
33 views and no one knows the answer, EEK! this is the CKeditor support forum right? or is there another support website? or email?
does anyone know if there is any documentation that will have the anser i'm looking for? just need to know simply how to transfer a website that uses CKeditor to another server, apart from copy+pasting the files what else am i missing to get it working. Desperatley need to find out....
