I have no idea if anyone can help me with this, but I have to try, since this is driving me bonkers.
I have a flash element in a page I am editing with the editor. The flash element needs to play automatically when the page loads; therefore, I'm told that the "Play" parameter in the HTML needs to be set to "-1". This works perfectly fine when I enter the flash element to begin with, but the moment I go to change something in the source OR save the page, the editor changes the setting to "0".
The line effected looks like this:
<PARAM NAME="Play" VALUE="0">
I can get around this by submitting the page while the source is open - it will then retain my setting. But, if I go back later and change something minor and submit with the regular editor showing - back to "0".
The really weird thing is that this happens sporadically depending on the flash element - it'll leave the play setting how I set it with some flash elements and will change it with others.
Is there any way to get the editor to NOT replace my flash settings?
