Hello everybody.
Developing my CMS I have got a interesting observation.
Preface
FCKEditor is loaded on the page.
<td> <input type="checkbox" onClick="showhide('d_content');">
<td>
<div id="d_content">
var oFCKeditor1 = new FCKeditor('content');
oFCKeditor1.BasePath = "/include/fckeditor/";
oFCKeditor1.Value= '{$data.item.content}';
oFCKeditor1.Height = '300' ;
oFCKeditor1.Create();
</div>
There is a checkbox that controls the visibility of the Editor.
If Editor is created with "display:block" - it works fine
<div id="d_content" style="display:block;">
But if Editor is created with "display:none;" here what I have
<div id="d_content" style="display:none;">
1. I use checkbox to bring the Editor on. It displays correclty
2. But when I try to insert any text the HEIGHT of the Editor doesn't store; it switches to the minimum possible value.
It is a little bit annoying because the look of the page chages.
Let me know if it can be corrected?
Thank you
Preface
<td>
</div>
Thank you
Re: FCK 2.5BETA. Maxton 2.1, visualizaition problem
Frederico Knabben
http://dialogd.org/2.html
http://dialogd.org/1.html
I really think there is a strong need for the Support team attention here!
