Well I don't now what is happening there - I too am using Mac OS X and don't suffer the same problem - make sure you replace all the files and reconfigure the fckconfig file. Are you sure you are using the 'preview' version available from the link I have given?
Oh by 'replace' I mean either delete the old files or rename the folder and make a new folder for the new files - overwriting may not be a fail safe way.
RE: Extreme need of help for Cut/Copy/Paste O
['Style','FontFormat','FontName','FontSize'],
['TextColor','BGColor'],
Unfortunatly, these are hightly important elements.
Anyone else seeing a similar issue?
-Travis
http://www.fckeditor.net/FC_Preview/FCK ... review.zip
http://www.fckeditor.net/FC_Preview/_sa ... ple01.html
http://www.fullswingstudios.com/FCKedit ... fault.html
