I have CKeditor 3.6.4 and I used the following code:
Everything works fine except {filebrowserImageBrowseUrl:'/df/dd.php'}
When I use the ckeditor config.js and supply it with the follwoing code it works fine:
I want the file browser initialize to work from jquery?! Does it a bug? or there is something missing?!
$("textarea").ckeditor(function(){extraPlugins : 'stylesheetparser'},{contentsCss : ['css/foundation.css','css/app.css','css/editor.css']},{stylesSet : []},{filebrowserImageBrowseUrl:'/df/dd.php'},{bodyClass: 'panel'});
config.filebrowserBrowseUrl = '/browser/browse.php';
Re: CKeditor 3.6.4 does not load filebrowser using Jquery!
I'm using CKEditor 3.6.4 (same bug in 3.6.3) and Google Chrome v.20
Any suggestion?
Thanks.
it should called by Jquery Like the following:
$("textarea").ckeditor(function(){},{extraPlugins : 'stylesheetparser',filebrowserImageBrowseUrl:['/filebrpwser']});Re: CKeditor 3.6.4 does not load filebrowser using Jquery!
Works fine on Firefox, but doesn't work in Chrome 20.
I'd like to confirm that configuration items should be written as propery: value as I stated in my previous post.
jQuery('#textarea').ckeditor({ filebrowserBrowseUrl : 'libraries/elfinder/elfinder.php.html', language : 'es', scayt_autoStartup : false, toolbarCanCollapse : false, height : '250px', resize_maxWidth : '100%', resize_minWidth : '100%', enterMode : CKEDITOR.ENTER_BR, toolbar : [ ['Font','FontSize'], ['Bold','Italic','Underline'], ['JustifyLeft','JustifyCenter','JustifyRight'], ['NumberedList','BulletedList','-','Outdent','Indent'], ['Link','Image','Table'], ['Cut','Copy','Paste','PasteFromWord'], ['TextColor','BGColor'], ['Undo','Redo'] ] });Re: CKeditor 3.6.4 does not load filebrowser using Jquery!
