If I try to load the _samples in that server it's working fine, so CKFinder is configured correctly and maybe your problem is that you are trying to use in in a cross-site environment You must call CKFinder from the domain where it's installed, if you try to install it in one domain and call it from another then the browser might reject that action.
It could work IF the page where you use CKFinder is also at cms.com. On the other side if you try to call cms.com from janklomp.com then you will have problems.
Re: CKFinder -asp - Problem with BaseDir
I already tried this, it gives no error
So it does not help me
Have you modified the config.asp beyond changing the authentication function and the baseUrl, baseDir parameters?
please visit login.xiteforce.nl/ckfinder/wizard/default.html
http://www.cms.com/ckfinder/default.asp
http://www.janklomp.com/files/
I call CKfinder from cms.com to get the maps/files from janklomp.com
What is the problem then?
