I have a problem when I try to upload files using the filemanager.
It works fine on when I try it on my computer, but when I try to upload to a remote host I can't. It shows me the content of the folder but it does not upload.
$Config['UserFilesPath'] = '/admin/filupload/' ; $Config['UserFilesAbsolutePath'] = ''.$_SERVER['DOCUMENT_ROOT'].'/admin/filupload/' ;
Re: BIG problems uploading files, PLEASE help
Examine /admin/fileupload/ folder and check if the script created subfolders "image", "file" or wathever. If not, create it manually.
(I solved the same problem doing this).
I AM using it in a remote host ... and works fine.
