I'm not sure about what you mean with "altered the code so it uses a physical path, not a virtual path", because there's no need to do that. in the configuration file you can state the physical path to your files without the need to touch any of the other files.
I was happier using a physical path for debugging purposes. It worked in neither with a virtual path, but thats probably my error. The physical path works fine in the test though? (I checked the ftp and uploaded images are there) Please, I would be extremely greatful for any help on this topic. Regards.
Cheers for the reply. I understand you dont know that - the fact is nothings been removed and at the bottom it loads up sedoparking.com during an upload - which i know is a domain parking holder.
I'll post the source code of configuration.asp tonight - but its not wrong, hence it working in the testupload page. Regards, Ricky.
Re: [ASP] Uploading Images Problem
This is rather urgent!
Regards.
or maybe it's in the fifth.
how can we know?
Regards, Ricky.
