Hi, I'm trying to use CKeditor for the first time, but I have some trouble to test the CKBuilder(costumize) version. The Full and Standard Package its OK.
So about the CKBuilder, I selected some Plugin, and whe I open the Documentations in "\ckeditor\samples" the Editor don't appears. I have to configure the plugins ? where am I going wrong ?
Thanks!
Would help to know which
Would help to know which plugins, skin, etc., you're using. Can you attach the build-config.js file?
build-config.js
Ok, thanks!!! I've been reading the documentation and I think I know what I'm missing. But, any help is appreciated.
My build-config attached.
See here: http://ckeditor.com
See here: http://ckeditor.com/comment/134909#comment-134909
I had the same problem. I have deleted the "Image Uploader" Plugin.
Thanks!!! I'll try.
Thanks!!! I'll try.
I'm thinking about Cache or another stuffs like configuration PHP.
