Hi having trouble uploading
When I click "image" and then click the "upload" tab I cannot upload files. I click browse, select a file and click "send it to the server". Nothing happens, no errors nothing, zip...
However If I click "browse server" and upload from there all works great
Obviously I am missing something here, does any one have ideas?
If i cant resolve this then is it possible to remove the upload tab from the intial popup and keep the one on the browse server popup?
BTW using ASP.NET
BTW using ASP.NET
Re: strange upload problem
I'm having a similar problem. When I try to upload an image I select it from my
hard drive and then click "send to server", but then I get a message saying "Not Found".
Any ideas?
Kap
Wiktor Walc
