Hi i am using the CK Editor .net control inside a multiview, this works fine when i save the content i then change the multiview index, if i then click any linkbutton on the page i get a js error of "Error: e is null", so no linkbuttons or buttons work after.
any ideas what is causing this?
Re: problems in multiview control
Wiktor Walc
I have a page with tab menu and wysiwyg on one of the tabs. After switching to another tab click on any link causes the error 'e is null'. So at the moment control that contains the editor, has visible = false. Maybe this is the reason.
If it does not help, please let me know.
I've tried to reproduce it using the attached file without luck (just put it into the _samples folder distributed with CKEditor.NET), so anything that can help us to reproduce it would be more than appreciated.
Ideally please provide a similar sample page + the set of steps to reproduce it.
Wiktor Walc
Please find a sample page in attachments.
(to reproduce the problem simply wander through the tabs)
Could you try the attached SVN version (rev 6709) of CKEditor ASP.NET control?
Wiktor Walc
I've checked the attached sample in Firefox 3.6.16 and got the following result:
- open_Samples/custommultiview.aspx (with Ajax enabled)
- click tab 2 (CKEditor appears correctly)
- click tab 1
- press F5 key to refresh the page
- click tab2 (CKEditor does not appear)
- Firebug shows the following response:
Did you have the same result? Could you attach some screenshots of the described issue?
Wiktor Walc
- open _Samples/custommultiview.aspx (with Ajax enabled)
- click tab 2
- see screenshot in attachment
non-existing
and config.js
Wiktor Walc
I've removed double slashes. Now I have this (tab2):
Wiktor Walc
