Dear forum members
We are running into a problem while using CKFinder with CKEditor inline option (using http://docs.ckeditor.com/#!/guide/dev_inline). The image properties does not show the browse option in inline mode. We are not sure why this is happening? The snippent of the code we are using is below:
// We need to turn off the automatic editor creation first.
CKEDITOR.disableAutoInline = true;
CKEDITOR.replace('editor1',
filebrowserBrowseUrl: '../ckfinder/ckfinder.html',
filebrowserImageBrowseUrl: '../ckfinder/ckfinder.html?Type=Images',
filebrowserFlashBrowseUrl: '../ckfinder/ckfinder.html?Type=Flash',
filebrowserUploadUrl: '../ckfinder/core/connector/aspx/connector.aspx?command=QuickUpload&type=Files',
filebrowserImageUploadUrl: '../ckfinder/core/connector/aspx/connector.aspx?command=QuickUpload&type=Images',
filebrowserFlashUploadUrl: '../ckfinder/core/connector/aspx/connector.aspx?command=QuickUpload&type=Flash'
var editor = CKEDITOR.inline('editor1');
CKEDITOR.inlineAll();
</script>Is this known problem with CKFinder while using it inline mode or we are doing something wrong? Suggestions are appreciated.
Many thanks
Dhaval
Innoventurous Business Solutions, UK
