My CKFinder resides on a site that is in a language that has characters with accents (French).
Some of the messages displayed don't appear properly.
For example when I upload a file more than once (or if a file with the same name already exists in my userfiles) the message that basically says that a file with the same name exists and that the uploaded file has been renamed appears in French as such:
Un fichier avec ce nom existe déjà . Le fichier téléversé a été renommé en "file(1).jpg"
instead of
However other messages, like the one asking me to confirm if I really want to delete a file displays the accented characters properly:
Êtes-vous sûr de vouloir effacer le fichier "file.jpg" ?
These two messages seem to be generated by a different mechanism. The message that is not displayed properly takes it's text from the file fr.xml while the other message takes it from fr.js.
I would like to be able to display all messages properly.
Is there a file that I have to modify to display properly the xml generated messages that have characters with accents?
Do I have to change in a given file the encoding from charset=utf-8 to something else? (For example, charset=ISO-8859-1). Which file would it be?
For example I have tried to change the encoding in file standalone.html to "charset=ISO-8859-1 " but that didn't correct the problem with my error messages in French.
Scribe
Note:
I am using the ASP version of CKFinder
Site developped in Visual studio 2003
instead of
Scribe
Note:
Re: Problem with messages with accented characters
I am sure there must be someone else that has tried CKFinder in a language that has accents.
I have also tried in Spanish. The message that says 'A file with the same name is already available. The uploaded file has been renamed to "6229961(17).jpg' in English appears the following way in Spanish:
Ya existÃa un fichero con ese nombre. El fichero subido ha sido renombrado como "file(1).jpg"
it should be:
Ya existía un fichero con ese nombre. El fichero subido ha sido renombrado como "file(1)"
Has anyone else had this problem? Any input would be appreciated.
I am having the problem in Internet Explorer (IE7 and IE8). I don't have the problem in Firefox (5.0.1).
Open the core/connector/asp/ErrorHandler/FileUpload.asp
and at line 55, just below the commented response.clear add this
Response.charset="utf-8"
Save it and now test again.
My tests are working fine and I get the correct messages.
Please, confirm that it has solved your problem.
While testing this issue I've found that filenames with non-ascii names aren't downloaded correctly with IE, but I can't make that work correctly. I've managed to adjust it so it can show correctly the file name, but in that case it appends a [1] after the extension, and I don't understand where that's comming from.
Thanks alfonsoml, once again you are a savior.
Concerning the upload of files named with accented characters, it seems to be working perfectly for me in Internet Explorer. For example, I have tried (in IE7) to upload a file named "FélìçitàtÏÔÑ.txt".
The file is uploaded perfectly with the right name. I view it without any problem and the warning message when I try to delete it displays the name of the file correctly (I will try with other versions of IE).
So for now everything is working fine thanks to your help (time for me to get my license).
Scribe
Works well in Firefox.
http://www.codeproject.com/KB/aspnet/NonUSASCII.aspx
Function ConvertToUTF8(sIn) Dim oIn: Set oIn = CreateObject("ADODB.Stream") oIn.Open oIn.Charset = "us-ascii" oIn.WriteText sIn oIn.Position = 0 oIn.Charset = "UTF-8" ConvertToUTF8 = oIn.ReadText oIn.Close End FunctionAttachments:
Response.AddHeader "Etag", Etag If (fileName<>"") Then Dim encodedName, browser encodedName = Replace(fileName, """", "\""") ' Encode filename for IE<9 browser = Request.ServerVariables("HTTP_USER_AGENT") Dim IEversion, oRegex, Matches Set oRegex = New RegExp oRegex.Pattern = "MSIE (\d+)\." set Matches=oRegex.Execute(browser) if (Matches.count>0) then IEversion = (Matches(0).submatches(0)) If (IEversion<9) then encodedName = Replace(Replace(Server.UrlEncode(encodedName), "+", " "), "%2E", ".") End if End If Response.AddHeader "content-disposition", "attachment; filename=""" & encodedName & """" End if Response.AddHeader "Content-Length", FileSizeRe: Problem with messages with accented characters
I have tried your very clever solution in IE7. The accented file name appears correctly in the File Download dialog. It is also captured correctly when we click the Save button to attempt to save the file.
However, when we click the Open button in the File Download dialog, the file name is not displayed properly in the caption of the window (of Notepad for example).
I have also tried with a file named simply file(1).txt , the filename in the caption of the Notepad window is also changed.
Please see the following images:
I have tried to put a Response.Charset="utf-8" somewhere in your solution so that the filename would be transferred correctly from the File Download dialog to Notepad, but it didn't work.
Any other solution?
Scribe
But now the problem is not only IE, but also how it passes data to other applications and if they are ready for encoded filenames or not. If instead of Open you click Save, the file will be saved correctly, but if you click open, you don't know where it has been saved, so I don't think that the filename is so important because you can't use it again. It's in a temp folder of IE, so it's usually out of reach for the user.
And also: I've tested and IE8 seems to be able to pass the data to notepad in a way that it can open the file with the expected filename, so your solution is just to upgrade that IE7 to IE8, or tell the users to save the file instead of try to open them directly
Thanks for your reply. I totally agree with your conclusion. I have tested it in IE8 and everything works well.
Thank you very much for your help. The clarity and precision of your replies were really appreciated.
I consider the two issues that were raised in this topic as being SOLVED!
A million thanks,
Scribe
Wiktor Walc
