Hallo,
I use CKEditor with CKFinder. I would like use one CKEditor + CKFinder "engine" for separate projects. So I need set different variable $baseUrl value with path to folders where each project has images, flashes etc. This is my web structure (simplified):
Engine/CKEditor/
Engine/CKFinder/
Project1/config/
Project1/CKFinderUserFiles/
Project1/ CKFinderUserFiles /images/
Project2/config/
Project2/ CKFinderUserFiles /
Project2/ CKFinderUserFiles /images/
I have 2 separate CKFinder config.php files saved in folder Project1 (or Project2)/config/ with variable value $baseUrl = http://myweb/Project1 (or Project2)/CKFinderUserFiles/ and I need sent information about config path (Project1(or Project2)/config/config.php) to Engine/CKFinder/core/connector/php/connector.php and set this information to constant "CKFINDER_CONNECTOR_CONFIG_FILE_PATH". I don't know how to do it..
Is any solution ?
Thanks a lot.
Milan
