Sorry for my english...
I use ASP CKFinder. I have a small upload problem. I'm using upload in images and small files and there is no problem. But i tried 1 megabyte file upload and nothings happen. No errors no happens. What is the problem?
Re: ASP Upload Problem
Try to use a simple upload test to check if there are any errors, or use Fiddler to check the response when CKFinder uploads the file.
I don't know Fiddler? And maybe you right. Maybe IIS have a limit. Because i test many files work greatly. But file size incresase about 1mb then problem appears. How can i change IIS upload limit. I use WinXP SP2 Turkish...
