Hi
I'm using the FCKEditor in phpList (not the CKEditor for not causing problems). Now I want to allow file upload in the FCKEditor described in the following two tutorials
http://www.dintillion.com/?p=77
http://www.electrictoolbox.com/fckeditor-php-enable-file-maneger-connector/
There it is written the following:
Unless your FCKEditor instance is protected via .htaccess with a username and password, by IP address or similar, you should normally never simply enable the connector as I have shown above, otherwise other people will be able to browse your server.
How can I protect FCKEditor with .htaccess? I want to use username and password.
Does somebody know an answer?
Does somebody know an answer? It is pretty important to me.
All we can do at this point
All we can do at this point is suggest moving to a newer version of CKFinder/CKEditor. Our FCKeditor guides are here. In them we recommend using sessions instead of manipulating your .htacess.
I think a newer version does
I think a newer version does not work with phpList.
Do you recommend manipulating the .htacess with the new version?
In the guide you linked I found only the following about sessions.
How can I use sessions to secure it?
Sessions use your site's user
Sessions use your site's user roles. So an admin will have access to certain files/folders, regular users to other files/folders, etc., depending on how your site's users are defined and how you set it up. A newer version would imply using CKFinder since CKEditor doesn't come with a file browser. Don't be afraid to download CKFinder and experimenting with it!
Do I have to protect the
Do I have to protect the whole FCKEditor folder or only some part of it? I want to use the FCKEditor in phpList and phpList uses a web interface, so it should be somehow accesible. I just want that other people are not able to browse my server through FCKEditor.
