I'm using FCKeditor 2.2 in IE6 sp 2. Applying styles works fine if you're applying a style to virgin text, but if you want to change the style, you have to manually edit the HTML. Is this a bug, or just a limitation? Seems like you should be able to just select the same text and apply a new style without any manual edits. (This worked in the old editor I've replaced withh FCKeditor, so my users are kinda antsy on this point.)
Doug
Doug
