i am using FCKeditor with bear house version, some how, i could not find any way to adjust the line spacing within paragraph. i believe you are using Literal control to display text from database. Is there any good way to adjust the line spacing wider ? if yes, how. thx.
David
David
Re: how can i adjust spacing within a paragraph
p {margin:0}Re: how can i adjust spacing within a paragraph
