Hello everyone,
I noticed that if you're placing a span inside another span the order is not respected...
if you have something like this:
the end result will be something like:
Notice thet the first span completely disappears and that the text itself is also switched around.
Also if this is a known problem and has been fixed in later updates please advice where the corrected code can be found so we can implement.
Since we've put a lot of work in this project simply upgrading to a higher version is no option as we would have to start all over.
Thanks again for any help on this issue...
<span1>first part of text <span2> second part of text </span1></span2>
<span2>second part of text </span2> first part of text
Re: even bigger problem... a span inside a span
Fix your source HTML and then things will start working.
I said that we're trying to do the following
But I made a mistake... this needs to be
I do not think that the last part is illegal code...
It is indeed a feact that the spans then are being switched around together with the text the end result of this is
Any idea's on why this is happening and what might be a solution??
