Hi all,
after some searches on the web, I don"t find how to do what I want.
My structure:
A php file, A.php, witch create a fckEditor instance, giving some parameters like BasePath, StylesXmlPath, CustomConfigurationFile ... etc
The Js custom configuration file with Plugin add, and EditorAreaCss path.
I see in some articles on the web, that it is possible to give to fckeditor more than one CSS for the Editor Area.
I see also in the code (fck.js i think) that we have loop to load all files in EditorAreaCSS variable.
What i want to do :
Add a css file for the editor area in the A.php. and keep the EditorAreaCss in the configuration file.
In other words, how can I put 2 files in the EditorAreaCSS variable one from the php instancing fck, and the other from the configuration file.
If it is not possible, how to include the 2 css files from the A.php?
I try to do this :
only the second one is used.
I try to put one in the config file and the other in the php.
Only the Css in the php file is used.
Some one knows how can I do this ?
My structure:
What i want to do :
I try to do this :
in A.php: $oFCKeditor->Config['EditorAreaCSS'] = array(); aray_push($oFCKeditor->Config['EditorAreaCSS'],"helloWorld.css"); aray_push($oFCKeditor->Config['EditorAreaCSS'],"helloWorld2.css");
