I'm trying to use upload fonction. But It does't work.
I've made the following things :
- I'm use fckeditor 2 with spip.
- I create a 'UserFiles' directory to the root of kfceditor directory
-I put a chmod 777 permissions for the 'UserFiles' directory and his dpendances (subfolder).
-I configurate ImageBrowserURL and LinkBrowserURL like this :
I don't know if I must change this variable
FCKConfig.LinkUploadURL ...
But anyway, when I try to use the upload browser to create a directory, I have a javascript alert which said :"You have no permission to create the folder".
So I've got forgotten something ?
Thanks for your help.
Best Regards
FCKConfig.LinkBrowserURL = FCKConfig.BasePath + "filemanager/browser/default/browser.html?Connector=connectors/php/connector.php" ; FCKConfig.LinkBrowserWindowWidth = screen.width * 0.7 ; // 70% FCKConfig.LinkBrowserWindowHeight = screen.height * 0.7 ; // 70% // Link Upload FCKConfig.LinkUpload = true ; FCKConfig.LinkUploadURL = FCKConfig.BasePath + "filemanager/upload/aspx/upload.aspx" ; FCKConfig.LinkUploadWindowWidth = 300 ; FCKConfig.LinkUploadWindowHeight = 150 ; FCKConfig.LinkUploadAllowedExtensions = "*" ; // * or empty for all FCKConfig.LinkUploadDeniedExtensions = ".exe .asp .php .aspx .js .cfm .dll" ; // empty for none // Image Browsing FCKConfig.ImageBrowser = true ; //FCKConfig.ImageBrowserURL = FCKConfig.BasePath + "filemanager/browser/default/browser.html?Type=Image&Connector=connectors/asp/connector.php" ; //FCKConfig.ImageBrowserURL = FCKConfig.BasePath + "filemanager/browser/default/browser.html?Type=Image&Connector=connectors/aspx/connector.aspx" ; FCKConfig.ImageBrowserURL = FCKConfig.BasePath + "filemanager/browser/default/browser.html?Type=Image&Connector=connectors/php/connector.php" ;
Best Regards
