Dear Fckeditor 2.6.x users,
I can't find out how to configure the fckeditor to solve the following problem:
When you enter a simple text, say
(where <TAB> means the tabulator key) you will have 4 spaces between a/b and b/c, respectively,
if your configuration is something like this:
So if you then enter a text like
you will see that the editor puts also 4 Blanks between ax and b.
So, it seems to me that the fckeditor does not count the blanks, no
text processing is done; but why?
Are there any configuration options to make the tab key "smarter"?
Any ideas about how to solve this problem? Please advice!
Best regards
toller43
a<TAB>b<TAB>c
var sBasePath = document.location.href.substring(0,document.location.href.lastIndexOf('_samples')) ;
var oFCKeditor = new FCKeditor( 'FCKeditor1' ) ;
oFCKeditor.BasePath = sBasePath ;
oFCKeditor.Config['ProcessHTMLEntities'] = false;
oFCKeditor.Config['ProcessNumericEntities'] = true;
oFCKeditor.Config['FormatIndentator'] = '\t';
oFCKeditor.Config['TabSpaces']= 4;
oFCKeditor.ReplaceTextarea() ;
ax<TAB>b<TAB>c
Best regards
toller43
Re: Tabulator Issue
http://dev.ckeditor.com/ticket/2740
Re: Tabulator Issue
to
did not help.
My idea was to change the TAB into a → by simply altering the configuration file.
The problem here is that even variations of '#8594' like '→' don't change the internally used TAB
character to the expected '→'.
The internally used FCKConfig.FormatIndentator is not used in the fckeditorcode_xxx.js files.
So, what can I do? Please help!
Best regards
toller43
