Is there a way I can turn on or off the FCK editor? In other words I would like to add a button that allows me to switch between the original textarea and the FCKEditor.
Can that be done?
Can that be done?
RE: Switching between Textarea and FCK
http://www.opensource.org/licenses/lgpl-license.php
http://www.fckeditor.net/
finn_hakansson@yahoo.com
<html> <head> <title>FCKeditor - Sample</title> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="robots" content="noindex, nofollow"> <link href="testcases.css" rel="stylesheet" type="text/css"> <script type="text/javascript" src="../fckeditor.js"></script> <script language="javascript"> // This the object that holds information about all editors. var editor_sets = new Object(); // This is how to register a new TEXTAREA/FCKeditor pair. // You can add as many as you wish. editor_sets['XYZ'] = { text_id : 'regular_editor', html_id : 'fck_editor' }; function new_editor(name) { var e = new FCKeditor(name); //e.Config["CustomConfigurationsPath"] = "../fckconfig_my_settings.js"; //e.ToolbarSet = "MyToolbar"; e.Width = "700"; e.Height = "700"; e.BasePath = "/FCKeditor/"; e.Create(); } function toggle_editor(name) { var editor_frame = document.getElementById(name + '___Frame'); var editor_source = editor_frame.contentWindow.document.getElementById('eEditorArea'); var x = ['', 'none']; var i = 0; if (document.getElementById(editor_sets[name]['text_id']).style.display == "") { var content = document.getElementById(name + '_textarea').value; editor_source.contentWindow.document.body.innerHTML = content; i++; } else { var content = editor_source.contentWindow.document.body.innerHTML; document.getElementById(name + '_textarea').value = content; } document.getElementById(editor_sets[name]['text_id']).style.display = x[i++]; document.getElementById(editor_sets[name]['html_id']).style.display = x[i%2]; // This is a hack for Gecko... it stops editing when the editor is hidden. if ( !document.all ) { var ed = FCKeditorAPI.GetInstance(name); if (ed.EditMode == FCK_EDITMODE_WYSIWYG) { ed.MakeEditable(); } } }; </script> </head> <body> <h1 id="Prova">FCKeditor - Test 011</h1> <P> <STRONG>Expected results</STRONG> : The editor must still work when hidding it programmatically (through javascript).<BR> <STRONG>Configurations</STRONG>: Default<BR> <STRONG>Steps to Reproduce</STRONG>: </P> <OL> <LI> Wait for the page to load. <LI> Insert some text. <LI> Click the "FCKeditor" link. <LI> Type some text in the FCKeditor. <LI> Click the "Regular Textarea" link. <LI> Hit the "Submit" and check the posted HTML. <LI> Close the "Submit" window. <LI> Hit the "Show Editor" button. </LI> </OL> <P> <hr> <P></P> <form action="sampleposteddata.asp" method="post" target="_blank"> <div id="regular_editor"> <table cols="1" rows="2" border="1"> <tr> <td> <table id="upper_row_textarea" cols="2" rows="1"> <tr> <td style="text-decoration: underline">Regular Textarea</td> <td><a href="javascript: toggle_editor('XYZ');">FCKeditor</a></td> </tr> </table> </td> </tr> <tr> <td> <textarea id="XYZ_textarea" cols=80 rows=30><b>Some</b> text to start with.</textarea> </td> </tr> </table> </div> <div id="fck_editor" style="display:none"> <table cols="1" rows="2" border="1"> <tr> <td> <table id="upper_row_FCKeditor" cols="2" rows="1"> <tr> <td><a href="javascript: toggle_editor('XYZ');">Regular Textarea</a></td> <td style="text-decoration: underline">FCKeditor</td> </tr> </table> </td> </tr> <tr> <td border="3"> <script type="text/javascript"> new_editor('XYZ'); </script> </td> </tr> </table> </div> <br> <input type="submit" value="Submit"> </form> </body> </html>
