IE7 Pro come with spelling functionality. The way to do it is right clicking on the field you want to check. But with FCKEditor, there is a context menu that prevent it.
Is it possible to integrate IE7Pro Spell checking in your context menu or called with the check button on your toolbar ? it will be very nice !
Thanks for your answer.
Re: Spelling with IE7 Pro
