As FCKEditor uses ID for field detection, and ID cannot contain [] chars (good if you want to exploit PHP's automatic array creation), I have made the following small patch to allow defining the name value for the value form element and ID separately:
You can set $fck->FieldName to differ from the ID value.
--- old-fck/fckeditor_php5.php 2008-09-24 13:29:20.000000000 +0300
+++ new-fck/fckeditor_php5.php 2008-09-24 13:28:35.000000000 +0300
@@ -122,6 +122,12 @@
public $Config ;
+ * Defines the name used for the submit value
+ * @var string
+ public $FieldName;
* Main Constructor.
* Refer to the _samples/php directory for examples.
@@ -130,6 +136,7 @@
public function __construct( $instanceName )
$this->InstanceName = $instanceName ;
+ $this->FieldName = $instanceName ;
$this->BasePath = '/fckeditor/' ;
$this->Width = '100%' ;
$this->Height = '200' ;
@@ -172,7 +179,7 @@
$Link .= "&Toolbar={$this->ToolbarSet}" ;
// Render the linked hidden field.
- $Html .= "<input type=\"hidden\" id=\"{$this->InstanceName}\" name=\"{$this->InstanceName}\" value=\"{$HtmlValue}\" style=\"display:none\" />" ;
+ $Html .= "<input type=\"hidden\" id=\"{$this->InstanceName}\" name=\"{$this->FieldName}\" value=\"{$HtmlValue}\" style=\"display:none\" />" ;
// Render the configurations hidden field.
$Html .= "<input type=\"hidden\" id=\"{$this->InstanceName}___Config\" value=\"" . $this->GetConfigFieldString() . "\" style=\"display:none\" />" ;
Re: Small patch to allow input name defining
--- old-fck/fckeditor.js 2009-03-27 18:24:58.000000000 +0100 +++ new-fck/fckeditor.js 2009-03-27 18:26:57.000000000 +0100 @@ -30,6 +30,7 @@ { // Properties this.InstanceName = instanceName ; + this.FieldName = instanceName ; this.Width = width || '100%' ; this.Height = height || '200' ; this.ToolbarSet = toolbarSet || 'Default' ; @@ -80,7 +81,7 @@ if ( !this.CheckBrowser || this._IsCompatibleBrowser() ) { - sHtml += '<input type="hidden" id="' + this.InstanceName + '" name="' + this.InstanceName + '" value="' + this._HTMLEncode( this.Value ) + '" style="display:none" />' ; + sHtml += '<input type="hidden" id="' + this.InstanceName + '" name="' + this.FieldName + '" value="' + this._HTMLEncode( this.Value ) + '" style="display:none" />' ; sHtml += this._GetConfigHtml() ; sHtml += this._GetIFrameHtml() ; }
