All you need to do is, just before you create your editor, assign an HTML string to the 'Value' property. An example is as follows:
<script type="text/javascript"> oFCKeditor = new FCKeditor('FCKeditor1'); oFCKeditor.BasePath = "/fckeditor/"; oFCKeditor.Value = "<p>This is the initial value of the editor.</p>"; oFCKeditor.Create(); </script>
Incidentally, you can also set the toolbar at creation as well, using oFCKeditor.ToolbarSet = "Basic";
Re: Setting default contents for editor
