I have found a troubling problem with the XHTML mode ... I hinted before that there might still be bugs but was unable to reproduce consistently to investigate.
I'm still not entirely sure how it happened, but I have a content item in my database which has problems being edited with IE. It initially displays fine, but when viewing source you get nothing, then when you switch back to WYSIWYG mode it too is blank.
When I write out the content from the database (before it gets loaded into the editor) I can see that *every* tag has an attribute _fckxhtmljob="1" on it!
If I set FCKConfig.EnableSourceXHTML = false , I can view source and I see all the _fckxhtmljob attributes
This has happened a couple of times before.
Making XHTML compulsory makes me a bit nervous unless we can sort this out!
Ben
Ben
RE: Serious problem with XHTML mode
Can you please show us the contents you have in your database?
Thanks in advance,
FredCK
Frederico Knabben
