Hi everybody,
FCKeditor seems to replace automatically ASCII characters, e. g. the ". In German the first one of the two " is at the bottom line, the second at the top line. If I want to use the correct characters, I have to use
So my question is: Does anybody know, where I have to look for the replacements that FCKeditor uses, so I can edit them?
Thanks in advance, regards
Jochen
„and
“. FCKeditor replaces #147 with
“, which unfortunately is not the same as #147.
Jochen
Re: Replacement of ASCII characters
CKEditor FCKeditorentities
Hello guys,You can use the entities configuration setting to solve the problem.
