Hi
I've been trying to create a plugin for the FCKEditor to automatically add tracking for Google Analytics for each link added. It works ok in Firefox as it uses the InsertHTML command but in IE8 I get the good old "Object expected" error which fails on the following function - SetAttribute. The updated code is below:
Has anyone tried to do anything similar, I've checked the forums to no avail. Any help or advice appreciated!
Cheers
Shaun
var oEditor = window.parent.InnerDialogLoaded() ;
var FCKLang = oEditor.FCKLang ;
var FCKSelectlink = oEditor.FCKSelectlink ;
var FCK = oEditor.FCK ;
window.parent.SetOkButton( true ) ;
Ok =function() {
if(typeof(document.forms.frmLinks.theLinks) != 'undefined'){
var theChoice = -1;
if(document.frmLinks.theLinks.length == undefined){
theChoice = 0;
theLink=document.forms.frmLinks.theLinks.value.split("^")
else {
for (counter = 0; counter < document.frmLinks.theLinks.length; counter++)
if (document.frmLinks.theLinks[counter].checked) {
theChoice = counter;
var theLink=document.forms.frmLinks.theLinks[theChoice].value.split("^");
if(theChoice != -1){
if(document.all)
var onclick;
var myDownload='TempValue';
mySelection = FCK.EditorDocument.selection;
if(mySelection.type=='Text'){
oLink = oEditor.FCK.CreateLink(theLink[0]) ;
onclick = "javascript: pageTracker._trackPageview(\'/downloads/'+myDownload+'\');";
onclick = encodeURIComponent( " onclick=\"" + onclick + "\"" ) ;
SetAttribute( oLink, 'onclick', onclick ) ;
else
FCK.Focus()
var myRange=mySelection.createRange();
myRange.text= theLink[1];
myRange.moveStart('character', -theLink[1].length);
myRange.select();
else
//mySelection = FCK.EditorDocument.getSelection();
mySelection = FCK.EditorWindow.getSelection();
if(mySelection.length > 0 ){
else
oEditor.FCK.InsertHtml('<a href="' + theLink[0] + '" onclick="javascript: pageTracker._trackPageview(\'/downloads/'+myDownload+'\');">' + theLink[1] + '</a>') ;
window.parent.Cancel() ;
else
}Has anyone tried to do anything similar, I've checked the forums to no avail. Any help or advice appreciated!
Cheers
Shaun
