I've just discovered that pasting text while using Netscape, Mozilla or Firefox outputs an empty box entitled [Javascript Application]. Is there a fix to this or a simple workaround? I really would like my users to be able to paste their text correctly. The problems doesn't seem to occur with Internet Explorer. Any advice would be appreciated.
RE: Paste in Firefox, Mozilla, Netscape probl
GL!
:Xd
RE: Paste in FireFox, Mozilla, Netscape probl
SelfMan
Someone who knows their config is stable could set it to the static value, so it is then cacheable.
Would probably cut down on the "x is broke" posts...
I do get it in the fckeditor.net demo as well.
I still kinda think it's a config/loader issue, as I haven't run into the problem, and I use FF alot.
I'm using the CF or JS version of the "loader" tho... have you tried using the JavaScript vs. ASP or whatnot?
