Hi.
I'm using multiple editors in same form.
Have created a custom button, using a fckplugin.js in the plugin dir.
here is the code that is triggered when user click on the custom button:
ExpandVertical.prototype.Execute = function()
window.parent.set_editor_height( WHAT_DO_I_PUT_HERE );
I need to return a reference to current editor which I can use in my set_editor_height function so I
can do something like this:
function set_editor_height(id){
document.getElementById(id).height = parseInt(document.getElementById(id).height) + 50;
what can I use instead of WHAT_DO_I_PUT_HERE in:
to make it work?
to make it work?
RE: Need a reference to current editor instan
using FCK.Name worked
