Did your user create a new directory? If so, maybe there's a problem with the directory name (invalid characters). Or were they just working with an existing directory?
Since you are using the fbxp version, you should be able to run that more comprehensive 'testme.php' or whatever. Does it not come back with any errors?
I too have had this problem with FBXP (which is a fantastic piece of work). I've got multiple users using the same editor, the basedir and url variables being assigned through sessions. All of a sudden I get that same Javascript error and the XML connector invalid data bit. Could you indicate what you changed in the config to get it working again?
Also, is anyone out there using session variables to control the user directory targets?
RE: Need help! Upload error came from nowhere
Cheers,
Ad
